Not really. The oil pump functions are several atmospheres are and can more than the vacuum in the crank case. A lot of race car use this trick. But you will have to make sure that all the engine seals can hold up to the abuse.
http://www.dragstuff.com/techarticles/vacuum-pumps.html
