12" x 6" pre drilled for 4 of the powerex cm400du-12f igbts , 4 mounting holes and 2 ports for cooling fluid.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
