Did someone say “water cooled IGBTs”?? This is what I’ve been working on. The white tape shows the 3/8” drilled coolant path in a ¾” aluminum plate.. It has 3, 300Amp IGBTs, and 16, 75Amp 1200V Hyperfast Diodes. The 4400uF caps are 300V..
Paul do you have any more of the IGBT driver boards?
[/IMG]
