Old 03-17-2011, 10:53 PM   #4482 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Originally Posted by twotires View Post
My question: Do you think (13) 470ufs will be OK - they should fit OK like the pic below - or should I spring an additional $60 and get the 25mm dia 820 ufs?
Are you reducing the current as well? Or do you still want 500A and 96V?
If you still want the 500A, you will need the correct caps. They are designed to filter the current ripple which will not differ with voltage.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
