Old 03-17-2011, 10:17 PM   #1 (permalink)
bandit86
Buggie - '01 Vw Beetle TDI Gls
installed scangaugeII - some questions
when cruising, the engine load% is never below 6%, even with downshifting and using engine braking, is that normal?
The intake air temperature is way too warm, it was at best 15degrees C toady and the gauge showed as high as 40 degrees, crappy intake routing?
