I recently read about the Kelly 600amp controller. Evidently, they use ten 330uF caps. Take it for whatever it's worth. 13 of the 470uF caps might be fine? The only reason I originally used 16 of the 820uF originally, and then 16 of the 1000uF was because it was the most I could fit in the space. I figured if that didn't work, then I was out of luck, since there would be no room.
