Old 03-18-2011, 06:05 AM   #3 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Yes, engine load never really hits 0%.
It will go to 0 when using DFCO on my diesel car.
(it's around 17-19 @ idle when warm ; up to 40 @ idle when cold)
when cruising, the engine load% is never below 6%, even with downshifting and using engine braking
Does your vehicle have fuel cut off when engine braking ?
The cut-off value can be changed. (manual page 16)
Try increasing the cut-off value a few points and see if the load is reduced to 0 while engine braking.
