The kit I'm using has a gearbox and then chain drive to the rear wheel so the rear sprocket isn't huge, only 44 teeth. It leaves the pedal mechanism totally alone on the other side so the bike can be used in a normal manner also, but with some mechanical drag unless you remove/disconnect the motor drive chain completely.
Yes, 2 stroke noise, smoke and pollution I can do without. The 2 strokes have some sort of cat converter, but how long will that be effective before oil plugs it up?
