Old 03-18-2011, 06:08 PM   #9 (permalink)
Ryland
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Shifting without a clutch just seems like a bad idea having had taken apart motorcycle transmissions and replacing automotive transmissions and driving vehicles that require you to double clutch, even if you don't feel it grinding it is still causing more wear to the syncros and to the bearings because it is putting a harsh sudden load, using the clutch takes all of the load off the moving gears, double clutching and matching the engine RPMs will also help in reducing wear but if you plan to drive fast enough that you feel you have to drive like this then please stay off the public road ways.
The Following User Says Thank You to Ryland For This Useful Post:
TEiN (11-06-2011)
