Old 03-18-2011, 06:56 PM   #11 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Originally Posted by ShadeTreeMech View Post
When upshifting, you would ease off the gas while pulling out of gear. In one movement, pull out of gear and try to put the stick in the desired next gear. The stick won't engage the gear until it is time. Wait for the engine to coast down, and when the revs match, with you putting gentle pressure on the stick in the direction of the desired gear, you'll feel it start to engage. Give it the push needed to fully engage, and there you go.
By upshifting, I take it you mean going from 2nd, to 3rd, to 4th, to 5th etc.
Upshifting is a bit trickier. It involves disengaging the current gear, revving the engine past where it needs to be for the next highest gear, then following the above mentioned step of allowing the engine to coast down to the correct rpms.
Don't you mean downshifting is tricker without using the clutch?
