Old 03-19-2011, 01:02 PM   #45 (permalink)
cliffyballs
Leftnut - '03 Volkswagen Jetta GLS
The build has begun
Okay i started building last night (pics to come) I decided to go with 1/2" pvc pipe as my internal support/shape. I will be using 1" steel pipe on the bottom part of the tail and where I need extra strength.
My thinking is using stronger pipe on the bottom is better because that is where the weight will be pushing. I went with PVC and Steel pipes because they are cheap, easy to cut, has fittings I can use (elbows, Ts,45s). Once the frame is built I plan to fiberglass it. I will drape the fiberglass cloth over the frame pull it tight and "paint" on my fiberglass.
Any thoughts on this?
Am I overlooking anything by using PVC?
Here is a pic of internal structure plan
http://i1217.photobucket.com/albums/...pportbuild.jpg
