Originally Posted by some_other_dave
It may also control the starter. My 1990 CRX uses a clutch switch to keep you from cranking the starter except when the clutch pedal is pressed.
-soD
there's actually two clutch switches.. one when you fully depress the clutch (starter interlock I guess) and one when you release the clutch. Cars today all have the switch when you fully depress the clutch, it's the one when you release the clutch that is unique to the VX/HX cars..
