Old 03-20-2011, 10:40 PM   #6 (permalink)
j12piprius
Liberty Lover
j12piprius's Avatar
pris prius - '12 Toyota plug in prius
90 day: 71.09 mpg (US)
Originally Posted by Ryland View Post
Get a $15 shop manual and it will tell you, there should be a fuse that you can pull then at least on the steering wheel there is a little yellow clip that you install that shorts it out so that there is no way it can go off.
Thanks, I'll check for a manual.
Any ideas where the clip can be found, or at least the name of it?
From what I have read, if you are wearing your seat belt air bags do very little to protect you, so in a way I agree with your desires
Thanks.
Any more info on how to remove the airbags is much appreciated.
