Old 03-21-2011, 04:53 PM   #1 (permalink)
Mad Professor
Looking to start an EV Project, Needing advice
Good day all.
I am looking at starting an EV project soon, but being a total newbe to the EV way of life I am going to need a fair bit of advice as I go along.
I am based in the UK, So I am trying to source all needed parts from within the UK where I can.
The donner car that I am wishing to use is a Peugeot 205 GTi, aprox stock weight 875-900Kg's.
The idea is to keep the standard running gear, and gearbox & cluch.
I am not looking for high speed or long range, as I only live on a 25x20mile island in the UK, most roads around me have a speed limit of 30 to 40MPH.
As I yet I have not brought any parts for this project as I need to work out what I need to get.
I guess the main things I need to look at are the main drive motor and controller.
With regarding to the drive motor I have been looking at getting the motor for a disused milkfoat that is local to me I have found out that the motor rated at 9KW @ 48volt, running speed of 1600RPM.
I have been looking into what gearbox to use, the standard 205 1.9 Petrol 5speed Gearbox would give a max speed of 34MPH, but if I was to fit the 205 1.8 Diesel Gearbox, that would give me a max speed of 42MPH.
So back to the drive motor again, so if it's 9KW @ 48volt thats 187.5amps right?
Is this the max current this motor will draw, and what rating fuses should I buy for use with this motor?
I am sure I will have more and more questions, as I get ready to start this project.
Thanks for your time.
Best Regards.
