Old 03-23-2011, 05:19 AM   #1 (permalink)
65impalass
Change to a single carb on twin? cm400.
I am looking at a basket case Honda cm 400. The carbs are off of it, witch is never a good sign. The Chain is also off of it. I believe all the parts come with it. What do you all think of building a manifold out of pvc, and epoxy, and mounting 1 carb instead of 2. It would probably have to be bigger than the ones that come on it. While I am at it I would change the gearing to lower rpm's.
