Old 03-23-2011, 08:07 AM   #4527 (permalink)
adamj12b
EVVette - '71 Chevy Corvette Coupe
Some things to remember about igbt modules. You need a 2 pack module minimum to build a controller. You need a switch and a diode. So with those modules being 1 pack modules, you will need 2 of them to build a controller. That means with the 4 modules you got, you will be able to build a 600A controller before derating. it would be wise to cut that 300A limit each back to probably 225A to 250A max.
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
