Originally Posted by E Vdubya
harlequin2
....And thank you for who posted the instructions etc.
John
That would be me since I'm the only one who's built one
I want to point out that some pics in the PCB assembly write-up will vary slightly from your build though. The original PCB had the 16-pin header holes too small, so I couldn't use the 16-pin socket/header shown in the bom. (I stupidly used a SIP-16 footprint rather than header). I had to cut up a wire wrap 40-pin dip socket since it had narrower pins. What you see is a much closer board to board spacing in the pics. Good enough for conveying the idea and of course the pad holes were enlarged for my release rev of the PCB.
Good luck and pm if you have any additional questions.
