Old 03-23-2011, 09:34 AM   #34 (permalink)
Piwoslaw
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
Part 5 is out - intercooler and conclusion
Fitting a larger IC seems to have brought performance down again, but has improved fuel economy.
So if there was no power increase, was the fitting of the larger intercooler a waste of time? For two reasons, I don’t think so.
Firstly, the fuel economy is clearly improved. This change is not visible in all driving: it seems more pronounced at higher speeds where loads are greater. In Part 4 of this series I said that typical fuel economy had improved to about 5.3 litres/100km. That is still the case in most circumstances, but in freeway use at a sustained 110 km/h, 5.1 litres/100km is now common.
The Following User Says Thank You to Piwoslaw For This Useful Post:
COcyclist (03-23-2011)
