Old 03-23-2011, 10:16 AM   #4 (permalink)
theycallmeebryan
2003 Ninja EX250 - '03 Kawasaki Ninja EX250
90 day: 78.57 mpg (US)
Saturn - '99 Saturn SL1 Base
90 day: 47.27 mpg (US)
Originally Posted by Franmcm View Post
Prety soon i will have results on the 15/33 and will let you know. I am just waiting for the rear sprocket to be ready. I like cars and motorcycles with very very long gearbox so riding them is full of decision making. This way i dont get bored of driving. If i could design my own veicule i would probably have 8 gears to choose from. For me a gearbox is not ok when you can mantain cruising speed when uphilling 5% with last gear.
While the ZZR250 has different gear ratios than the Ninja 250, i still think 15/33 (2.20 final drive) will be too low and may actually be detrimental to your fuel economy.
I've crunched some numbers in gearcommander. If you have a stock rear tire (140/70-17), with a 15/33 you'll be doing 50mph at 4123rpms.
I've got a 15/39 (2.60 final drive) setup on my Ninja 250, and in 6th gear its a 1mph per 100rpm ratio, and seems perfect.... lugging the motor a little bit, bit not that much. Leaving from a stop i have to use a bit more clutch to prevent it from bogging.
I've found that cruising 55mph at 5500rpm is perfect on flat ground with this engine. If there is any sort of upgrade in the road, with a steady throttle position I'll lose a good 5mph or so, maybe 10 if its steep enough.
Thus, i'd advise you to shoot for a 1:100 ratio as well. For your bike, that would be a 15/40 setup, if you are using stock tires.
Doing my part to reduce dependence on OIL
Doing my part to reduce congestion
And enjoying it!
If you have to use your brakes, you are driving too fast!
My 101.5 MPG 2003 Kawasaki Ninja 250
Crude Oil Price Today
