Old 03-23-2011, 11:59 AM   #54 (permalink)
carolina guy
Stormtrooper - '14 Ford F-150 XLT, 4x4, Crew Cab 5.0
30 seems high...
I have a 2004 Mercury Mountaineer (same as the Explorer) with the 4.6l V8 and all wheel drive. My normal daily commute (70% city / 30% highway) I get 18.5 mpg w/o the AC pretty much by following the posted speed limits and tires at 45 psi. If I get impatient in traffic and jack rabbit all over the place, it drops to 16.5 mpg pretty quickly.
Now...on the highway I can EASILY get 25 mpg. This according to the on-board FE display.
Here is how that is done:
1) stay at or below 65mph
2) no AC
3) look ahead and keep a relatively light touch on the throttle and avoid dramatic changes in speed
If I go 75mph, I get 20 mpg and if I turn on the AC it drops to 19 mpg.
If I draft a semi, I can get 28 mpg at 70 mph easily and it gets closer to 30 mpg if the truck is going slower. This is WAY too dangerous for much driving, so I rarely do it.
There are no other mods on the car, it needs a tuneup (67k miles) and I am sure that if I dropped the running boards, got smaller mirrors, put a good airdam on the front, took the rest of the roof rack off (it never had the cross pieces) and even lowered it a few inches it would do better.
However, by far, the best increases in mpg that I have seen are leaving early and just listen to the radio and relax. :-)
