Old 03-23-2011, 04:26 PM   #10 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by mort View Post
Hi smchristin,
The current theory, which would be easy to test but is not demonstrated in any real engine, is as follows.
First, the amount of hydrogen needed is substantial, like a few thousand watts of electrical power to hydrolyze water. In theory, the added hydrogen allows an extremely lean mixture of gasoline to burn. The normal air to fuel ratio for gasoline is 14.7:1 But if you could get a mixture of 200:1 to burn the cylinder would have 12 times as much air in it for the same amount of fuel. The thermodynamic efficiency of the engine is determined by the high temperature during combustion. If the cylinder has more air in it then there will be higher pre-combustion pressure and when the fuel is burned there will be a higher combustion temperature. So the efficiency will be higher.
The effect should be to get the engine to have the nearly the same efficiency at low power levels that it has at it's most efficient operating point. Maximum engine efficiency for modern cars is about 25% and at low power, as low as 10%
-mort
I know logic normally has no place in this forum, but please explain how burning extra hydrogen and oxygen in the proportions generated via electrolysis will cause your engine to run lean? Or did you leave out the caveat of leaning your fuel system in addition to fumigation with "HHO"?
