Old 03-23-2011, 04:45 PM   #37 (permalink)
Arragonis
The PRC.
Originally Posted by Piwoslaw View Post
I've been thinking about the freer flowing intake today. I don't know about the TDI turbo, but my HDi's turbo has variable geometry, and this lead me to a thought experiment:
The ECU is constantly checking boost pressure and tweeking the turbine's geometry to keep boost where it is supposed to be. So if the pre-turbo intake is opened up (less restrictive = lower pressure drop = higher pressure delivered to turbo) the ECU adjusts geometry to 'scoop up' less. Post-turbo pressure is the same (ECU made sure of that), but the turbo is doing less work, i.e. less work is extracted from the exhaust.
So, opening up the pre-turbo intake has the same effect as reducing exhaust back pressure. And is probably cheaper.
TDIs have VNT turbos.
My thoughts have led me to conclude this won't work. The inlet side is cancelled out by the turbo - it boosts to the same pressure as long as enough air is coming in. If you improve it then it makes no difference.
The same for the exhaust - remember better exhaust flow only works for high-revving petrol cars. The exhaust diameter on my TDI is larger than any petrol car I have ever had.
Nope - this engine has all the air it needs. I still maintain if Julian removed everything else and kept the remap the power gains would still remain.
I'm willing to bet a bottle of wine on it.
