i'm fairly certain that the motor voltage limit is only because of the rpm limit of the motor (higher voltage=higher rpm.) running much over 200 could lead to the motor over-revving and damaging itself i think. i'm not POSITIVE on this though, i need to contact the motor manufacturer and see what they say. We've added different brushes and bearings to the motor already that increased the voltage limit a little from stock, but i'll need to check and see what the insulation breakdown voltage is.
but yeah, everything you said is correct.
If the voltage pulses are a problem i could probably come up with a low pass filter circuit that would average the voltage...essentially the same thing that happens in a rectifier. i'm not sure how pre-charge would be taken care of though.
