Hello Rik
I haven't updated this thread for a while but have been updating my fuel log as I fill up. I recently had a full service done (£1400!!!) and found lots of problems, particularly with suspension, which had to be replaced. Luckily I had already bought a lowering kit - all good quality coil over shocks - from Belgium. That whole kit cost the equivalent of one set of VW spring/shock so at least I saved something. I also had the oil replaced with synthetic to reduce friction. It was always a good runner, being a fairly low mileage car, so I can't say that I've noticed a difference in the drive at all. While they were servicing I also asked them to replace the wing mirrors with aero DT Cup style mirrors to reduce drag.
The result is quite disappointing. I was regularly getting 60mpg (UK) at 60mph before the service and that figure has stayed the same. The only difference is that I can also now get 60mpg at 70mph, where before I was getting closer to 56mpg. So it looks like the aerodynamic performance has increased, but the economy has stayed the same. I'm a little confused by this.
To answer your question, at 70mph my rev counter says just under 3000rpm and I think at 60mph its about 2600, or close to it.
I'd be interested to hear your stories on running veg oil. This is something I definitely want to do - at least some cheaper alternative for diesel.
Please keep in touch as I'm sure we can work together to find some fuel saving tips for our cars.
Regards,
Steve
Efficiency is doing things right; effectiveness is doing the right things.
Peter Drucker
