Old 03-24-2011, 09:50 AM   #8 (permalink)
Daox
30-40 miles per charge really puts you in lithium territory IMO. You will be hard pressed to get that out of a lead acid pack. I wouldn't even consider using the float batteries. You need to boost the voltage if you want to increase the efficiency of the system.
