Old 03-24-2011, 04:23 PM   #4 (permalink)
UFO
UFO's Avatar
Colorado - '17 Chevrolet Colorado 4x4 LT
90 day: 23.07 mpg (US)
Originally Posted by Joenavy85 View Post
that's what i was thinking, but i'm not sure how the heck to calibrate it for different cars/engines
Presumably the inputs would be documented, then it's up to you how to modify your accelerator and MAP signals to fit the input ranges required. Most sensors are fairly standard, so all you may have to do is splice into the ECU harness and run wires to it.
I'm not coasting, I'm shifting slowly.
