Originally Posted by mystere485
The door jam says its a y, and the car for sure is a 1994.
8.8" carrier, 3.08:1 ratio, non limited-slip.
OEM tires sizes for the
'94 Crown Vic is 215/70-15 (26.9" OD, 751 rev/mi) or 225/60-16 (26.6" OD, 757 rev/mi), depending on the options.
The next taller diff gear available is 2.73's, or the equivalent of changing your tires to a 30" diameter.
