Old 03-24-2011, 09:49 PM   #6 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
The motor has a compression release, so it shouldn't be so bad to pull start, but I got the electric start option because I'm just not that ambitious...
You can search for 'Launtop Diesel 10hp', that will show you what I'm working with. I can't post a link here because my phones browser doesn't think it's a text input situation.
Regarding the transmission, I actually have a few options... The ZX600D 'box came to mind, but then I realized I have several other options that may be better, and will dev check into them as well.
The easiest option would be a pre-built detached transmission such as those used on older V Twin bikes of which I won't mention the names...
However, the chances of someone GIFTING me one of those is certainly slim. Thus, I'll have to cut up an integrated setup, and make something work.
