Old 03-24-2011, 10:03 PM   #87 (permalink)
NHRABill
NHRABill's Avatar
Tahoe - '95 Chevrolet Tahoe LT
90 day: 13.22 mpg (US)
SRX - '04 Cadillac SRX AWD
XL - '05 Harley Davidson Sportster XL
90 day: 49.97 mpg (US)
Alero - '02 Oldsmobile Alero GLS
Corvette - '75 Chevrolet Corvette Stingray
WOW what a thread ... so much info don't know where to start?
1st off good luck on the crown vic good durable car that can take a beating..
On that note you are a fool to cut your coil springs there are dozens of reasons I say that but mainly its because your ride will suck because the spring has everything to do with its rating and little to do with its height.
back int he 70's if you wanted to lower a car take a torch t o the spring heat it till itglows throw a few frinds on that side of the car and voila you have a low rider with zero suspension. aerodynamics from this Umm no ...
If you want to lower your car put it on airbags and save weight but be ready to shell out a lot of cash. How do I know this? if you have any practical auto knowledge or moron friends that you warned a dozen times that still do it then.... well you know... or f you like to race cars and want the tires to hook up you learn fast how to triangulate your suspension and how adjustable drag shocks and progressive springs are a godsend.
Tires whis on the Vic i would go with a 235 in the front and a 245 out back using a 70 series sidewall to retain a close to stock ride height but less meat on the road but enough to be safe. I rad 215/60/15 on my vette and even 195 65 15 on a firebird on my street strip cars a while back and they are terrible and unsafe on the street when you have 3200lbs or more rwd car.. 235 seemed just right in handling.
As far as mods I would try and lower your airdam a inch or 2 but would first find a speedbump on an empty road or parking lot and measure the height you have to play with before you do so. also note curb height when pulling straight in how far forward it is and so on...
Shed some weight from the car lose the spare and keep the engine purring smooth most people overlook buying a new coil and in my opinion it is a must replace every 100,000 miles i need to put a new one on my truck lousy weather keeping me from working on it.
Good luck
2012 Chevrolet Traverse *active*
2002 Oldsmobile Alero GLS *active*
2002 S10 2wd p/u 139,000mi. *active*
1975 Corvette Stingray *active*
1994 Camaro Z28 Convertible 149k *Sold 2013*
1998 Blazer ZR2 189k *Sold 2012*
1995 Tahoe LT 250k *Sold 2011*
