I assure you that Christ knows the limitations of a 10hp motor
But the cool thing is all the stuff it can run on, and 250g/kwh is pretty good bsfc for a little engine so it should be real efficient at cruising. The more he streamlines/gears up the faster he can go at 250g/kwh
