Old 03-24-2011, 11:22 PM   #26 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
...In a standard Prius (not a plugin) even the regenerative braking energy came originally from the gasoline burned earlier. So, if your definition of a hybrid (two different energy sources) is correct, then how is a Prius a hybrid?...
Well a train without batteries doesn't recapture and store that braking energy, or otherwise allow the vehicle to move without the diesel engine being on. If you take the batteries out, then a series hybrid is not a hybrid anymore, it is an electric version of a torque converter, instead of a pump and a motor you have a generator and a motor.
The storing of energy allows more efficient (hybrid) energy management schemes, and not just losses from weird transmissions.
