Old 03-25-2011, 07:26 AM   #18 (permalink)
RobertSmalls
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Originally Posted by dcb View Post
gawd, love that torque "curve" It's like an electric motor that runs on chicken renderings.
If you can target your averages cruise load/speed for that 3000 rpm mark, that will be about as good as it gets efficiency wise.
The BSFC curve is for a fully loaded engine at that RPM. Assuming you won't be P&G, you'll want it geared so that your typical cruising RPM is just high enough to overcome aerodynamic drag. I downshift for hills on the interstate, and I wouldn't have it any other way. And if you don't want to downshift, you could always pull a Rollie Free.
The Following User Says Thank You to RobertSmalls For This Useful Post:
Christ (03-25-2011)
