Old 03-25-2011, 02:21 PM   #23 (permalink)
Varn
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
If you use a japanese transmission make sure your get one with a chain drive primary. Otherwise you will have a motorcycle that runs backward. The Japanese usually use a design that the output shaft is not on the same as the input shaft.
Older british and american use the same shaft for input and output.
Noah Webster, 1787
