Old 03-25-2011, 05:16 PM   #123 (permalink)
apowers
apowers's Avatar
I got the LCD in the car. All I am getting is pack voltage and acc voltage.
Both of those are reading low. By 10 volts on the pack. The instructions tell how to adjust that. The acc battery is off by 1/2 volt but dropped as I drove by another volt.
When I had this on the bench it read the correct voltage for the acc. bat.
I am not getting motor amps , battery amps or motor temp. I did not hook-up battery temp.
I will get back at it to find my mistake(s).
Alvin
