Old 03-25-2011, 05:26 PM   #24 (permalink)
tscheerer
Here's another periodic update on my Insight EV project. Have removed the fuel tank assembly and have some pics showing the components. While doing this, noticed that where the tank was is a perfect spot to mount a battery box. It would be low, in the center of the car, and below the raised area of the floor behind the seats. Due to the hump there, the batteries would likely not hang lower than the fuel tank did, so they would be tucked up under the car nicely. Bought a 72v/20a charger and went to Batteries Plus to look at their 105ah deep cycle batteries. I'm leaning towards 6 12v 105ah batteries for the initial power supply, the pack weight should be about 400lbs. Plan on a 12v battery similar to OEM in the engine compartment for the accessories & lights with an alternator running off the electric motor secondary output shaft. The motor will mate to a GM manual trans. Mounting the driveline and adapting half shafts from the GM pattern to the Insight pattern should be the major hurdles going forward.
ID:	8016   Click image for larger version
ID:	8017   Click image for larger version
ID:	8018   Click image for larger version
ID:	8019   Click image for larger version
The Following 2 Users Say Thank You to tscheerer For This Useful Post:
IamIan (03-26-2011), mort (03-25-2011)
