Jackbauer,
Thorough video as usual for you
Nice to see the battery amp match the motor amps within 1A, when you consider the 2A steps of controller and rounding errors in firmware.
A little surprised to see the 2C error between controller temp and the other two. Mine only shows 1 deg F difference which is less than 1C. Controller does
use a different thermistor type and lookup table though.
-Chris
