I'm not actually using the termistor specified for the controller. Its a 10k ntc sourced locally. Probably why its a bit off. Far from a problem in any event.
Now, Cole, when you shift the gear and that little needle on the ammeter goes into the red and reads 2000 Amps, that's bad.
www.evbmw.com
