Originally Posted by Varn
I would say that 2000 rpm may be too high for max economy. My 3.8 Ford v6 is better at 1500-1700.
With the method I'm using it is only a 2k in first and second subsequent shift are at lower rpms. Sure is worth a try though.
You need an instantaneous fuel gauge to tell.
No argument there. If it could only log ever time you accelerate from a stop and tell you which one you did better on and if the conditions were the same. Then you would more easily be able to improve.
You won't believe how little throttle opening and speed will drink your fuel.
Oh but I do!
The ultra gauge keeps reminding me.
