Old 03-27-2011, 01:00 PM   #8 (permalink)
Joenavy85
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Originally Posted by kir_kenix View Post
Sometimes I pull a small trailer (500-700 lbs), and I often have 250-400lbs in the box for work. That is the only thing that gives me pause on gear ratio swap.
First step is definitely a Scangauge (or an ultragauge). Grill block would likely be the second step. since you tow a trailer occasionally and carry stuff in the bed i would try to find a good dyno chart for your particular engine before considering a rear end swap (don't want to bog the engine down with the extra load). when monitoring temps an ultragauge is nice because you can set an alarm to sound at a certain temp, so if you normally run around 190 you can set the alarm for 200.
