bwilson4web -
Originally Posted by bwilson4web
Perhaps they need heliocopter liftable, generators with sufficient power to handle emergency power needed for "n" power plants. When not applied to the power plants, use them as "topping" systems elsewhere in the grid.
Bob Wilson
Yeah, I said that earlier :
http://ecomodder.com/forum/225478-post29.html
3 - They did transport new power generators into the site, but I don't know if this was part of an existing Plan-B or just improvisation. You could have heavy lift choppers for generators and diesel fuel on standby for just this scenario. The only requirement would be a high-ground heliport (aka tsunami-proof) that could get the generators and diesel-fuel to the reactor *and* installed before the backup batteries went dead. This does not address the possibility that the helicopters and/or backup-backup generators would *also* be damaged in the initial earthquake.
However, the power attachments were *also* in the basement. You'd have to design the building to have multiple locations for power input. You'd need top and side connections. It would have to be "wired for power".
CarloSW2
