Old 03-28-2011, 11:43 AM   #115 (permalink)
euromodder
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Piwoslaw View Post
The first thing to get effected by the thinned oil is the turbine.
Turbine, as in turbo I'd think ?
you have to fix the frequent burnout problem.
Easier said than done, when even the dealer can't find the cause.
Pug owners claim that if the regeneration cycles happen every 100km or less, then the DPF must be replaced.
This is supposed to be a new DPF, I have only 12.000 km on it.
It was already regenerating quite frequently before replacement.
I don't know how often as I didn't keep track back then - but there's a note in my garage log here about 5 regenerations in some 900km.
It's back (or still) at that regeneration frequency despite the DPF swap.
Though it is possible that one of the pressure sensors is malfunctioning (there are two presssure sensors in the exhaust: based on pressure before and after the DPF the ECU decides whether it is clogged*). A faulty sensor should show up on specialized diagnostic instruments, like Peugeot Planet.
For a dealer, that should be something that's easy to spot, I'd think.
It's also what the service manager said it could be.
If you've ruled that out then maybe your ECU needs to be reprogrammed?
Would be lovely if they programmed the DRIVe software in it
But that probably won't be compatible.
BTW, I not sure your Volvo does this, but in Pugs the rear window and mirror heaters turn off during regeneration to increase the load on the engine.
On I guess ?
If it does so, then it doesn't show on the indicator lights in the switches nor on the dash.
I'm amazed at the milage you're getting despite all these problems
Yeah, cheers
Worst case scenario if they can't sort it out, I'll push Volvo into issuing a new Certificate of Conformity for a non-DPF vehicle, sorting the official paperwork, and removing all DPF assorted junk.
