So I have those Miata wheels soon to be ready to put on the car
( 10.8 Lbs version here:
Table of Wheel Weights )
So I have been planning on using Honda Insight (Gen1) factory size tires, why? One due to their LRR factor, two due to their very low weight (13lbs)
Bridgestone Potenza RE92 )
However if you look at that link to TireRack you will notice that the 175 65 14 is "only" 15lbs each or on the car 8 lbs extra. So here is my question, which would you vote for? 165 with slight smaller height (and circumference) than the stock 185 60 14 (stock on the donor Jetta TDI).
I plan on using the .622 5th gear gearing ratio, here is the calculations I got from here:
Tire, wheel, gearing calculator with engine rpm, top speed, spacer, and offset information
NOTE: "Current" is something I most likely will never be using but it would be TDI stock wheel setup WITH the .622 gearing & "planned 3" is to be ignored all together.
For anyone who might be confused I never went with any Golf 2 or big/small bumper I went with a
GOLF 3!
![Smile](/forum/images/smilies/smile.gif)
More info on project here:
http://forums.tdiclub.com/showthread.php?t=305898
