Old 03-28-2011, 12:09 PM   #34 (permalink)
jamesqf
...and so why would adding range to an EV with a genset, suddenly turn the electric motor into a mere transmission?
It doesn't (unless you've taken the batteries out). Think of those power paths. With range-extended EV, you have two paths: 1) battery -> motor -> wheels, 2) IC engine -> generator -> motor ->wheels. In path 2, the motor is part of the transmission, in path 1 it's a separate power source. Two (or more) paths = hybrid.
