Old 03-28-2011, 10:07 PM   #36 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Originally Posted by IamIan View Post
Actually you do get to down size the ICE considerably... even without any traction buffering batteries in the system.
No, because you can add a "granny gear" to a regular transmission, with a lot greater transmission efficiency than driving a generator driving a motor. The inefficiency of such a setup will marginalize/negate your ability to downsize the engine.
but the term hybrid is not exclusive to energy storage methods
The phrase "hybrid vehicle" is not that nebulous though.
"According to the U.S. Department of Energy, a hybrid vehicle is one that employs two separate power sources, typically a gasoline-powered engine and an electric motor, which is powered by rechargeable batteries. Hybrid vehicles also feature a regenerative braking system, which, when combined with the dual power sources, allows hybrid vehicles to maximize fuel efficiency while reducing the negative impact to the environment."
A motor without electricity is just an anchor. A motor supplied electricity from an engine and a generator is just a really horribly inefficient transmission. A motor with a regen controller and batteries and an engine to supply additional motive force (either supplementing rotational energy or electrons) is undisputably a hybrid vehicle.
