Old 03-29-2011, 07:29 AM   #9 (permalink)
Joenavy85
Making Ecomods a G thing
Angie - '08 Infiniti G35 X
90 day: 22.03 mpg (US)
Originally Posted by Creeper View Post
A short ram air intake on ebay should do the trick or not running your heaters till the car warms up an alternative is to buy a set of plug in heated seats for your car and plug them into your cigaret lighter leave the car in access mode in the morning let them warm up then start and drive off.
a short ram intake will work best once the engine bay is mostly closed off, which will keep more heat in the engine compartment. If the car is kept in a garage i would get an AC adapter that those seat covers could plug into so you aren't using battery power (that the alternator will have to replenish), until you get into the car and start it
