Old 03-29-2011, 07:52 AM   #12 (permalink)
3dplane
3dplane's Avatar
14 Mirage - '14 Mitsubishi Mirage DE
90 day: 68.74 mpg (US)
Originally Posted by gabi View Post
so.... i bought a pair of solar panels 5 watts each to install in my car,back window
the problem is that i have tinted windows 75%, and i knew i wont get the rated power,but i'm berely getting about 1 watt from each panel....and thats at high noon ,perpendicular exposure to the sun
thats at load,when they are hooked to the battery
at no load i get a little better, about 2.25 watts out of each
You can not measure wattage without load. Only open voltage which is meaningless by it self.
While the panel is connected to a battery, measure voltage,then disconnect to hook meter in line in the circuit to measure amps if you only have one meter.
(V x A = W )
So maybe you are getting closer to rated then you think at this point : )
