Further clarification - the peak bsfc number always occurs at 100%load, and because of the amount of power that most engines produce, they can't actually get to 100% load, which means wasted movement, wasted efficiency.
Either method, the idea is to keep the engine loaded. The bsfc curve for a given engine changes dynamically with varying load... How it changes depends entirely on the engine and the duty.
