Old 03-29-2011, 09:43 PM   #140 (permalink)
Freyguy
EV Builder
Freyguy's Avatar
Yeah, sorry if it wasn't clear in all my previous info, but the LCD brd is intended to drive an analog gauge directly and assumes a ground referenced sender.
Analog Devices makes digital pots that work up to +30V. The AD7376 comes to mind.
The problem is going to be finding a digital pot with such a low resistance. 10K~100K is the normal range of these devices. You can't really parallel something like this with a 200~300ohm resistor and expect to get somethig useful. It will be terribly nonlinear with the pot only impacting overall resistance near the end of its overall step range. Maxim makes a DS3906 for low ohm applications, but its 5V, so stuck again.
I suppose you could build your own low resistance ladder network with several analog switches (silicon not mechanical) and resistors. Need at least 6 bits (64 steps), but now you need a 6-bit parallel interface to the micro. I'll think on this some more........
