Old 03-30-2011, 02:45 AM   #3 (permalink)
alvaro84
alvaro84's Avatar
Teresa - '04 BMW F650CS
Motorcycle
90 day: 80.53 mpg (US)
The YARDIS - '99 Toyota Yaris 1.0
90 day: 59.52 mpg (US)
I almost always coast in gear, with the clutch in. I've tried to shift to N then back, but if our bikes are not in the right mood, the gears grind scarily when I try to shift out of N over ~30km/h (<20mph). I'm sure it does no good to them.
I often shift to N when I want to go to a full stop FASed, though. Makes the glide a bit longer. Not shifting down as your bike slows down can also help a tiny bit (just don't forget to shift to a correct gear before you pulse). And, at higher speeds, tucking yourself behind the windscreen helps more.
The Following User Says Thank You to alvaro84 For This Useful Post:
Rick323 (03-30-2011)
