Old 03-30-2011, 10:58 AM   #12 (permalink)
Christ
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by Joenavy85 View Post
i don't think it will give any thrust at all, i believe it will just reduce drag based on the favorable vectors as mentioned above. much like rounding the rear part of the front fender as mentioned in the 65+ modifications list.
I a mannerof speaking, the only way to remove from one is to give to the other, and vice versa... In other words, if you are reducing drag in one vector, you're increasing thrust in the opposite vector. It's still net negative. Semantics.
